It is currently Tue Aug 12, 2025 12:39 am
 Post subject: New go bar deck
PostPosted: Wed Jul 20, 2016 12:27 am
So part of the bench upgrade was to make a new go bar deck. My day job (home appraiser) has kept me super busy so I've had no time in the shop but got a couple hours in there tonight. So I made my new go bar deck.
I wanted a few options for it. I wanted it to turn so I used a 1/2" dowel at the center and waxed the bottom, it is easy to turn but doesn't free spin which is just fine by me.
I also wanted new go bars and wanted to try the fiberglass rods like most folks use. Having heard all the hassles of the round rods blowing out by slipping I figured a good idea would be to use some peg board on the upper deck to keep the rods in check. Works great.
I got the driveway markers from Home Depot as they were only $1.25 each. I bought 50 of them, cut them to the proper length and put the cap back on. The tapered end is perfect for the peg board.
I also wanted to only have 1 length of rod so I made a 4" riser which I can add or remove depending on what I'm gluing up.
In this picture I've got 27 rods set and I'm sure I could just keep on adding them, but I doubt I'll be using much more than that at one time...
Thanks for looking. Maybe this will help others with the dreaded go bar explosion.
 Post subject: Re: New go bar deck
PostPosted: Wed Jul 20, 2016 5:48 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Looks like a useful deck. I like the rotating design.
Speaking just for myself, I have never had a problem with the fiberglass rods slipping up top. I leave the top ends pointy, and the top of my deck is construction grade plywood, which is rough and relatively soft. The pointy ends dig in and hold on pretty well.
My beef with the round fiberglass rods is that the lateral forces can be unpredictable. You put the rod in place, then after you let go it decides it wants the bend to point another direction. That can cause real problems down where the blunt end (capped) is pressing down on a tall and thin brace blank. So, I am thinking of switching to wooden go bars with a rectangular profile. Then I will know where the lateral forces are pushing before I let go.
PostPosted: Wed Jul 20, 2016 7:52 am
City: Lawrence
Zip/Postal Code: 66047
I like the peg board idea, I'll probably steal that from you.
PostPosted: Wed Jul 20, 2016 10:55 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I too like the pegboard idea. My deck is actually my bench and plywood screwed into the ceiling above. I don't really have much issue with the rods slipping but I do sometimes have trouble getting them plumb. Many of my rods are longer than they should be and have a lot of bend in them. This makes positioning the top ends directly above the bottom ends a little tricky and sometimes I end up with a lot of lateral pressure. With the peg board, I have a convenient grid to help. I may just end up drawing a grid on the upper plywood and making reference marks plumb below. Thanks for the inspiration.
Bryan Bear PMoMC
PostPosted: Wed Jul 20, 2016 11:31 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I put a piece of carpet on the upper deck to grab the pointed tips of the rods. Same driveway markers as yours, Rod, but from the dollar store.
Alex
PostPosted: Wed Jul 20, 2016 3:50 pm
Nice!
PostPosted: Wed Jul 20, 2016 5:16 pm
Don, I have made quite a few flyrods in my day and like go bars they have a spline which you have to find. You can easily find it by bending the rod. Put one end down on a piece of wood and push down with your hand (a block of wood will protect your palm and let the rod pivot ) when the rod is bent it will pivot and bend opposite the spline. It wants to bend that way every time. Sometimes you have to help it a bit because the ends are digging into the wood or the rubber caps are causing too much friction. You can mark the spline with a sharpie or you can get a feel for where it is while you are installing them. Not unpredictable at all. You might have to take the cap off so the rod can pivot more easily but it wants to go to one spot everytime.
L.
These users thanked the author Link Van Cleave for the post (total 4): Imbler (Wed Jul 20, 2016 10:34 pm) • Alex Kleon (Wed Jul 20, 2016 9:53 pm) • Rod True (Wed Jul 20, 2016 8:33 pm) • Bryan Bear (Wed Jul 20, 2016 8:29 pm)
PostPosted: Wed Jul 20, 2016 6:14 pm
Link, that's awesome info. Time to test them all and pull the sharpie out.
PostPosted: Wed Jul 20, 2016 8:29 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Great tip Link!
Bryan Bear PMoMC
PostPosted: Wed Jul 20, 2016 8:35 pm
Oh and fly rods.... Hmmm a nice medium to heavy action 10' 5wt for still water trout fishing would do just fine please and thank you.
PostPosted: Thu Jul 21, 2016 12:02 am
Rod, you must be fishing out of a tube or pontoon boat to want a 10'. I love stillwater and Salmon and steelhead fishing. Have fished a fair amount in your great province but never still water. Kamloops is on the list. Give me an old RPL 590 , Cortland ice blue intermediate and a Hardy Marquis.
L.
PostPosted: Thu Jul 21, 2016 1:15 am
Yes I tube and pontoon fish although getting close to that longing for a boat all around....
10,000 lakes in the area to fish, we'll never hit them all.
PostPosted: Thu Jul 21, 2016 6:13 am
Last Name: Parker
City: Charleston
That's great info on the fiberglass rods, Link! Really appreciate it.
PostPosted: Wed Jul 27, 2016 9:11 pm
I love the pegboard idea, Rod!
Users browsing this forum: DennisK and 59 guests
